network interface check cluster-connectivity show
Display the Cluster Connectivity Log
The network interface check cluster-connectivity show command displays the cluster check result log.
[-fields <fieldname>,…]-
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-n ](privilege: advanced) -
Selects IP addresses instead of LIF names.
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Selects cluster health records that match the specified node name.
[-record-number <integer>]- Record Number (privilege: advanced)-
Selects the cluster health records that match specified record number.
[-date-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Record Date (privilege: advanced)-
Selects the cluster health records that match the specified date and time.
[-src-name <text>]- Source LIF Name (privilege: advanced)-
Selects the cluster health records that match the specified source LIF name.
[-src-addr <IP Address>]- Source IP Address (privilege: advanced)-
Selects the cluster health records that match the specified source IP address.
[-dst-name <text>]- Destination LIF Name (privilege: advanced)-
Selects the cluster health records that match the specified destination LIF name.
[-dst-addr <IP Address>]- Destination IP Address (privilege: advanced)-
Selects the cluster health records that match the specified destination IP address.
[-loss {None|Partial|All}]- Packet Loss (privilege: advanced)-
Selects the cluster health records that match the specified loss value.
The following example displays the cluster connectivity records.
cluster1::> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
node1
8/26/2020 10:35:36 -04:00 node1_clus_1 node1_clus_2 none
8/26/2020 10:35:37 -04:00 node1_clus_1 node2_clus_1 none
8/26/2020 10:35:38 -04:00 node1_clus_1 node2_clus_2 none
8/26/2020 10:35:39 -04:00 node1_clus_2 node1_clus_1 none
8/26/2020 10:35:40 -04:00 node1_clus_2 node2_clus_1 none
8/26/2020 10:35:41 -04:00 node1_clus_2 node2_clus_2 none
node2
8/26/2020 10:35:36 -04:00 node2_clus_1 node2_clus_2 none
8/26/2020 10:35:37 -04:00 node2_clus_1 node1_clus_1 none
8/26/2020 10:35:38 -04:00 node2_clus_1 node1_clus_2 none
8/26/2020 10:35:39 -04:00 node2_clus_2 node2_clus_1 none
8/26/2020 10:35:40 -04:00 node2_clus_2 node1_clus_1 none
8/26/2020 10:35:41 -04:00 node2_clus_2 node1_clus_2 none
12 entries were displayed.
