ONTAP commands
network interface check cluster-connectivity show
Display the Cluster Connectivity Log
The network interface check cluster-connectivity show command displays the cluster check result log.
[-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-n ] (privilege: advanced)
Selects IP addresses instead of LIF names.
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
Selects cluster health records that match the specified node name.
[-record-number <integer>] - Record Number (privilege: advanced)
Selects the cluster health records that match specified record number.
[-date-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Record Date (privilege: advanced)
Selects the cluster health records that match the specified date and time.
[-src-name <text>] - Source LIF Name (privilege: advanced)
Selects the cluster health records that match the specified source LIF name.
[-src-addr <IP Address>] - Source IP Address (privilege: advanced)
Selects the cluster health records that match the specified source IP address.
[-dst-name <text>] - Destination LIF Name (privilege: advanced)
Selects the cluster health records that match the specified destination LIF name.
[-dst-addr <IP Address>] - Destination IP Address (privilege: advanced)
Selects the cluster health records that match the specified destination IP address.
[-loss {None|Partial|All}] - Packet Loss (privilege: advanced)
Selects the cluster health records that match the specified loss value.
The following example displays the cluster connectivity records.
cluster1::> network interface check cluster-connectivity show
                                  Source          Destination     Packet
Node   Date                       LIF             LIF             Loss
node1
       8/26/2020 10:35:36 -04:00  node1_clus_1    node1_clus_2    none
       8/26/2020 10:35:37 -04:00  node1_clus_1    node2_clus_1    none
       8/26/2020 10:35:38 -04:00  node1_clus_1    node2_clus_2    none
       8/26/2020 10:35:39 -04:00  node1_clus_2    node1_clus_1    none
       8/26/2020 10:35:40 -04:00  node1_clus_2    node2_clus_1    none
       8/26/2020 10:35:41 -04:00  node1_clus_2    node2_clus_2    none
node2
       8/26/2020 10:35:36 -04:00  node2_clus_1    node2_clus_2    none
       8/26/2020 10:35:37 -04:00  node2_clus_1    node1_clus_1    none
       8/26/2020 10:35:38 -04:00  node2_clus_1    node1_clus_2    none
       8/26/2020 10:35:39 -04:00  node2_clus_2    node2_clus_1    none
       8/26/2020 10:35:40 -04:00  node2_clus_2    node1_clus_1    none
       8/26/2020 10:35:41 -04:00  node2_clus_2    node1_clus_2    none
12 entries were displayed.
