system switch ethernet temperature show
Display temperature information for Ethernet switches (cluster, management and storage).
The system switch ethernet temperature show command displays the temperature status of switches monitored by the Ethernet switch health monitor.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-device <text>]- Switch Name
Selects the temperature sensors that belong to the specified switch.
- [-sensor-name <text>]- Sensor Name
Selects the temperature sensors that match the specified temperature sensor name.
- [-index <integer>]- Sensor Index
Selects the temperature sensors that match the specified sensor index.
- [-temperature <integer>]- Temperature in Celsius
Selects the temperature sensors whose readings match the specified temperature value.
- [-threshold-severity {Unknown|Other|Information|Degraded|Minor|Major|Critical|Fatal}]- Threshold Severity
Selects the temperature sensors that match the specified threshold severity.
- [-threshold-value <integer>,…]- Threshold Value
Selects the temperature sensors that match the specified threshold value.
- [-sensor-status {normal|warning|alert|critical|not-present|not-operational|unknown}]- Temperature Status
Selects the temperature sensors that match the specified operational status.
- [-display-name <text>]- Sensor Display Name
Selects the temperature sensors that match the specified sensor display name.
- [-unique-name <text>]- Sensor Unique Name
Selects the temperature sensor that matches the specified unique name.
- [-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]- Health Monitor
Selects the temperature sensors that the specified health monitor continuously monitors.
- [-error-description <text>]- Error Description
Selects the temperature sensors that match the specified fault error description.
- [-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Resource Status
Selects the temperature sensors that match the specified status.
cluster1::> system switch ethernet temperature show
                             Threshold  Threshold
Switch  Sensor       Reading Severity   Value      Status   Error
SwitchA "Module-1, Intake-1"
                     24      Minor, Major
                                        40, 50     normal
SwitchA "Module-1, Intake-2"
                     23      Minor, Major
                                        40, 50     normal
The example above displays temperature status for all Ethernet switches (cluster, management and storage).
 PDFs
PDFs
