system switch ethernet temperature show
Display temperature information for Ethernet switches (cluster, management and storage).
The system switch ethernet temperature show
command displays the temperature status of switches monitored by the Ethernet switch health monitor.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-device <text>]
- Switch Name-
Selects the temperature sensors that belong to the specified switch.
[-sensor-name <text>]
- Sensor Name-
Selects the temperature sensors that match the specified temperature sensor name.
[-index <integer>]
- Sensor Index-
Selects the temperature sensors that match the specified sensor index.
[-temperature <integer>]
- Temperature in Celsius-
Selects the temperature sensors whose readings match the specified temperature value.
[-threshold-severity {Unknown|Other|Information|Degraded|Minor|Major|Critical|Fatal}]
- Threshold Severity-
Selects the temperature sensors that match the specified threshold severity.
[-threshold-value <integer>,…]
- Threshold Value-
Selects the temperature sensors that match the specified threshold value.
[-sensor-status {normal|warning|alert|critical|not-present|not-operational|unknown}]
- Temperature Status-
Selects the temperature sensors that match the specified operational status.
[-display-name <text>]
- Sensor Display Name-
Selects the temperature sensors that match the specified sensor display name.
[-unique-name <text>]
- Sensor Unique Name-
Selects the temperature sensor that matches the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]
- Health Monitor-
Selects the temperature sensors that the specified health monitor continuously monitors.
[-error-description <text>]
- Error Description-
Selects the temperature sensors that match the specified fault error description.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Resource Status-
Selects the temperature sensors that match the specified status.
cluster1::> system switch ethernet temperature show Threshold Threshold Switch Sensor Reading Severity Value Status Error ------- ------------ ------- ---------- ---------- -------- -------------- SwitchA "Module-1, Intake-1" 24 Minor, Major 40, 50 normal SwitchA "Module-1, Intake-2" 23 Minor, Major 40, 50 normal
The example above displays temperature status for all Ethernet switches (cluster, management and storage).
