job schedule interval show
PDF of this doc site
Creating your file...
Show interval schedules
The job schedule interval show
command displays information about interval schedules.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-cluster <Cluster name>]
- Cluster-
Selects the interval schedules that match this parameter value.
[-vserver <vserver name>]
- Vserver-
Selects the interval schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
[-name <text>]
- Name-
[-days <integer>]
- Days-
Selects the interval schedules that match the day value or range of values you specify.
[-hours <integer>]
- Hours-
Selects the interval schedules that match the hour value or range of values you specify.
[-minutes <integer>]
- Minutes-
Selects the interval schedules that match the minute value or range of values you specify.
[-seconds <integer>]
- Seconds-
Selects the interval schedules that match the second value or range of values you specify.
[-description <text>]
- Description-
Selects the interval schedules that match the description you specify.
The following example displays information about all interval schedules:
cluster1::> job schedule interval show Cluster Vserver Name Description ------------- ----------- ----------- ----------------------------------------------------- cluster1 data_vs_1 rollingdaily Every 8h
