ONTAP commands
job schedule interval show
Show interval schedules
The job schedule interval show command displays information about interval schedules.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cluster <Cluster name>] - Cluster
Selects the interval schedules that match this parameter value.
[-vserver <vserver name>] - Vserver
Selects the interval schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
[-name <text>] - Name
[-days <integer>] - Days
Selects the interval schedules that match the day value or range of values you specify.
[-hours <integer>] - Hours
Selects the interval schedules that match the hour value or range of values you specify.
[-minutes <integer>] - Minutes
Selects the interval schedules that match the minute value or range of values you specify.
[-seconds <integer>] - Seconds
Selects the interval schedules that match the second value or range of values you specify.
[-description <text>] - Description
Selects the interval schedules that match the description you specify.
The following example displays information about all interval schedules:
cluster1::> job schedule interval show
Cluster       Vserver     Name        Description
cluster1      data_vs_1
                          rollingdaily
                                      Every 8h
