job schedule interval show
Show interval schedules
The job schedule interval show command displays information about interval schedules.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-cluster <Cluster name>]- Cluster
Selects the interval schedules that match this parameter value.
- [-vserver <vserver name>]- Vserver
Selects the interval schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
- [-name <text>]- Name
- [-days <integer>]- Days
Selects the interval schedules that match the day value or range of values you specify.
- [-hours <integer>]- Hours
Selects the interval schedules that match the hour value or range of values you specify.
- [-minutes <integer>]- Minutes
Selects the interval schedules that match the minute value or range of values you specify.
- [-seconds <integer>]- Seconds
Selects the interval schedules that match the second value or range of values you specify.
- [-description <text>]- Description
Selects the interval schedules that match the description you specify.
The following example displays information about all interval schedules:
cluster1::> job schedule interval show
Cluster       Vserver     Name        Description
cluster1      data_vs_1
                          rollingdaily
                                      Every 8h
 PDFs
PDFs
