volume move recommend show
PDF of this doc site
Creating your file...
Display Move Recommendations
The volume move recommend show
command displays moves that were recommended by the Auto Balance Aggregate feature.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a Vserver that matches the specified value.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a volume that matches the specified value.
[-creation-time <MM/DD/YYYY HH:MM:SS>]
- Time Stamp of Recommendation (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a creation-time that matches the specified value.
[-source-aggregate <aggregate name>]
- Unbalanced Aggregate Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a source-aggregate that matches the specified value.
[-source-space-after <percent>]
- Space Free After Move (%) (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a source-space-after that matches the specified value.
[-destination-aggregate <aggregate name>]
- Destination Aggregate Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a destination-aggregate that matches the specified value.
[-destination-space-after <percent>]
- Space Bump After Move (%) (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a destination-space-after that matches the specified value.
The following example displays information about the recommendations made by the Auto Balance Aggregate feature.
cluster1::*> volume move recommend show -instance Vserver Name: vs0.example.com Volume Name: ro10 Time Stamp of Recommendation: 3/13/2014 16:26:39 Unbalanced Aggregate Name: aggr_1 Space Free After Move (%): 36% Destination Aggregate Name: aggr_3 Space Bump After Move (%): 36%
