volume move recommend show
Display Move Recommendations
The volume move recommend show
command displays moves that were recommended by the Auto Balance Aggregate feature.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a Vserver that matches the specified value.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a volume that matches the specified value.
[-creation-time <MM/DD/YYYY HH:MM:SS>]
- Time Stamp of Recommendation (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a creation-time that matches the specified value.
[-source-aggregate <aggregate name>]
- Unbalanced Aggregate Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a source-aggregate that matches the specified value.
[-source-space-after <percent>]
- Space Free After Move (%) (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a source-space-after that matches the specified value.
[-destination-aggregate <aggregate name>]
- Destination Aggregate Name (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a destination-aggregate that matches the specified value.
[-destination-space-after <percent>]
- Space Bump After Move (%) (privilege: advanced)-
If this parameter is specified, the display will be limited to only those recommendations with a destination-space-after that matches the specified value.
The following example displays information about the recommendations made by the Auto Balance Aggregate feature.
cluster1::*> volume move recommend show -instance Vserver Name: vs0.example.com Volume Name: ro10 Time Stamp of Recommendation: 3/13/2014 16:26:39 Unbalanced Aggregate Name: aggr_1 Space Free After Move (%): 36% Destination Aggregate Name: aggr_3 Space Bump After Move (%): 36%
