volume move recommend show
Display Move Recommendations
The volume move recommend show command displays moves that were recommended by the Auto Balance Aggregate feature.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a Vserver that matches the specified value.
- [-volume <volume name>]- Volume Name (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a volume that matches the specified value.
- [-creation-time <MM/DD/YYYY HH:MM:SS>]- Time Stamp of Recommendation (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a creation-time that matches the specified value.
- [-source-aggregate <aggregate name>]- Unbalanced Aggregate Name (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a source-aggregate that matches the specified value.
- [-source-space-after <percent>]- Space Free After Move (%) (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a source-space-after that matches the specified value.
- [-destination-aggregate <aggregate name>]- Destination Aggregate Name (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a destination-aggregate that matches the specified value.
- [-destination-space-after <percent>]- Space Bump After Move (%) (privilege: advanced)
If this parameter is specified, the display will be limited to only those recommendations with a destination-space-after that matches the specified value.
The following example displays information about the recommendations made by the Auto Balance Aggregate feature.
cluster1::*> volume move recommend show -instance
                   Vserver Name: vs0.example.com
                    Volume Name: ro10
   Time Stamp of Recommendation: 3/13/2014 16:26:39
      Unbalanced Aggregate Name: aggr_1
      Space Free After Move (%): 36%
     Destination Aggregate Name: aggr_3
      Space Bump After Move (%): 36%
 PDFs
PDFs
