statistics lif show
Logical network interface throughput and latency metrics
This command continuously displays performance data for LIFs at a regular interval. The command output displays data in the following columns:
LIF - logical interface name.
Vserver - vserver name.
Recv Packet - packets received per second.
Recv Data (Bps) - bytes received per second.
Recv Errors - receive errors per second.
Sent Packet - packets sent per second.
Sent Data (Bps) - bytes sent per second.
Sent Errors - transfer errors per second.
Current Port - current use port.
[-lif <text>]- LIF-
Selects the LIF for which you want to display performance data.
[-vserver <vserver name>]- Vserver-
Selects the vserver for which you want to display performance data.
[-sort-key <text>]- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>- Maximum Number of Instances-
Specifies the maximum number of LIFs to display. The default setting is 25.
The following example displays LIFs statistics:
cluster1::> statistics lif show
cluster1 : 12/31/1969 16:00:04
Recv Sent
Recv Data Recv Sent Data Sent Current
LIF Vserver Packet (Bps) Errors Packet (Bps) Errors Port
node2_clus_1 Cluster 3 536 0 3 338 0 e0a
node2_clus_2 Cluster 3 398 0 3 287 0 e0b
node1_clus_2 Cluster 3 338 0 3 536 0 e0b
node1_clus_1 Cluster 3 287 0 3 398 0 e0a
node2_mgmt1 ncluster-1 0 0 0 0 0 0 e0c
node1_mgmt1 ncluster-1 0 0 0 0 0 0 e0c
