vserver locks show-mirrored-open-count
Display mirrored open count
The `vserver locks show-mirrored-open-count ` command displays number of mirrored opens on node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter displays node name.
[-mirrored-open-count <integer>]- Mirrored Open Count-
This parameter displays mirrored opens count on node.
The following example displays the mirrored opens count on node1.
cluster1::> vserver locks show-mirrored-open-count Node Mirrored Open Count ------------- ------------------- node1 40
The following example displays the mirrored opencount for HA pair cluster.
cluster1::> vserver locks show-mirrored-open-count Node Mirrored Open Count -------------- ------------------- node1 20 node2 30
