ONTAP commands
vserver locks show-mirrored-open-count
Display mirrored open count
The `vserver locks show-mirrored-open-count ` command displays number of mirrored opens on node.
{ [-fields <fieldname>,…​]
| [-detailed ]
This option displays detailed count of type of locks persisted on this node.
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter displays node name.
[-mirrored-open-count <integer>] - Mirrored Open Count
This parameter displays mirrored opens count on node.
[-persistent-locks <integer>] - Persistent Opens
This parameter displays count of opens persisted on node.
[-mirrored-locks <integer>] - Mirrored Opens
This parameter displays count of opens mirrored on node.
The following example displays the mirrored opens count on node1.
cluster1::> vserver locks show-mirrored-open-count
Node               Mirrored Open Count
node1              40
The following example displays the mirrored opencount for HA pair cluster.
node1              20
node2              30
