ONTAP commands
system switch ethernet modify
Modify information about an Ethernet switch's configuration
The ` system switch ethernet modify ` command modifies information about an Ethernet switch (cluster, management or storage). The Ethernet switch health monitor uses this information to monitor the switch.
-device <text> - Device Name
Specifies the device name of switch that you want to monitor.
[-address <IP Address>] - IP Address
Specifies the IP address of the switch's management interface.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}] - SNMP Version
Specifies the SNMP version that ONTAP uses to communicate with the switch. The default is SNMPv2c.
{ [-community <text>] - DEPRECATED-Community String or SNMPv3 Username
Note This parameter is deprecated and may be removed in a future release of ONTAP. Use -community-or-username instead.
Specifies the community string for SNMPv2 authentication or SNMPv3 username for SNMPv3 security.
| [-community-or-username <text>] - Community String or SNMPv3 Username }
[-type {cluster-network|management-network|storage-network}] - Switch Network
Specifies the switch type.
[-is-monitoring-enabled-admin {true|false}] - Enable Switch Monitoring
Specifies the switch admin monitoring status.
cluster1::> system switch ethernet modify -device SwitchA -address 2.3.4.5
Modifies the IP address for the switch named SwitchA.
cluster1::> system switch ethernet modify -device SwitchB -snmp-version SNMPv3 -community-or-username snmpv3u1
Modifies the SNMP parameters for the switch named SwitchB.
