ONTAP commands
storage aggregate show-auto-provision-progress
Display aggregate auto provision status
The storage aggregate show-auto-provision-progress command displays the status of the most recent auto provision operation. The command output displays the progress for all the aggregates included in the provisioning operation. The command displays the following information about each aggregate:
  • Aggregate
  • Current Usable Size
  • Target Usable Size
  • Provisioning Progress
The following example displays the information about all aggregates that are provisioned during the aggregate auto provision operation:
cluster1::> aggr auto-provision
Node               New Data Aggregate            Usable Size
node1              node1_SSD_1                       23.65GB
node2              node2_SSD_1                       23.65GB
Total:             2   new data aggregates           47.30GB
Do you want to create recommended aggregates? {y|n}: y
Info: Aggregate auto provision has started. Use the "storage aggregate
      show-auto-provision-progress" command to track the progress.
cluster1::> storage aggregate show-auto-provision-progress
                                  Current       Target
Aggregate                     Usable Size  Usable Size Provisioning Progress
node1_SSD_1                            0B      23.65GB Creating
node2_SSD_1                            0B      23.65GB Creating
                                  Current       Target
node1_SSD_1                       23.65GB      23.65GB Completed
node2_SSD_1                       23.65GB      23.65GB Completed
