security key-manager external aws restore
Restore missing keys of AWS KMS
This command retrieves and restores any unrestored keys associated with the given Vserver to each node's internal key tables.
-vserver <Vserver Name>- Vserver-
This parameter specifies the Vserver to which the missing keys will be restored.
The following command restores missing keys for the data Vserver v1 (which has AWSKMS enabled) to the internal key tables on each node in the cluster.
cluster-1::> security key-manager external aws restore -vserver v1
