storage firmware shelf delete
Delete a shelf firmware file
The storage firmware shelf delete
command deletes the specified shelf firmware file from all nodes that are currently part of the cluster.
-filename <text>
- Storage Firmware Filename (privilege: advanced)-
Specifies the firmware file to delete.
The following example deletes the shelf firmware file with the name IOM12.0210.SFW on each node:
cluster1::*> storage firmware shelf delete -filename IOM12.0210.SFW
