volume file async-delete client enable
Enable async delete of a directory from the client
The volume file async-delete client enable command enables async delete of a directory on the volume, from client applications. When async directory delete from the client is enabled, 'mv' or 'rename' of a directory, to the trashbin name, triggers async delete of the directory.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume resides.
-volume <volume name>- Volume Name (privilege: advanced)-
This specifies the name of the volume.
[-trashbin <text>]- Trashbin Directory Name (privilege: advanced)-
This specifies the name of the trashbin directory.
The following example enables async delete of directory in volume "vol1" hosted in Vserver "vs1" from client.
cluster1::*> volume file async-delete client enable -vserver vs1 -volume vol1 -trashbin ntaptrash
