The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume file async-delete client enable
PDF of this doc site
Creating your file...
Your file is ready
Enable async delete of a directory from the client
The volume file async-delete client enable
command enables async delete of a directory on the volume, from client applications. When async directory delete from the client is enabled, 'mv' or 'rename' of a directory, to the trashbin name, triggers async delete of the directory.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume resides.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the volume.
[-trashbin <text>]
- Trashbin Directory Name (privilege: advanced)-
This specifies the name of the trashbin directory.
The following example enables async delete of directory in volume "vol1" hosted in Vserver "vs1" from client.
cluster1::*> volume file async-delete client enable -vserver vs1 -volume vol1 -trashbin ntaptrash
