The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port broadcast-domain move
PDF of this doc site
Creating your file...
Your file is ready
Move a layer 2 broadcast domain to another IPspace
Move a broadcast domain to another IPspace.
-ipspace <IPspace>
- IPspace Name-
The IPspace to which the broadcast domain belongs.
-broadcast-domain <Broadcast Domain>
- Layer 2 Broadcast Domain-
The name of the broadcast domain.
-to-ipspace <IPspace>
- Name of the destination IPspace-
The name of the destination IPspace.
The following example moves the broadcast domain named "mgmt" from IPspace "Default" to IPspace "Default-1".
cluster1::network port broadcast-domain> move -ipspace Default -broadcast-domain mgmt -to-ipspace Default-1
