qos policy-group show
Display a list of policy groups
The qos policy-group show command shows the current settings of the policy groups on a cluster. You can display a list of the policy groups and you can view detailed information about a specific policy group.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-policy-group <text>] - Policy Group Name
Selects the policy groups that match this parameter value
Policy groups define measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
[-vserver <vserver name>] - Vserver
[-uuid <UUID>] - Uuid
[-class <QoS Configuration Class>] - Policy Group Class
[-pgid <integer>] - Policy Group ID
This uniquely identifies the policy group
[-max-throughput <qos_tput>] - Maximum Throughput
A maximum throughput limit specifies the throughput (in IOPS or MB/s) that the policy group must not exceed.
[-min-throughput <qos_tput>] - Minimum Throughput
A minimum throughput specifies the desired performance level for a policy group.
[-num-workloads <integer>] - Number of Workloads
Selects the policy groups that match this parameter value.
[-throughput-policy <text>] - Throughput Policy
Selects the policy groups that match this parameter value. You can specify the throughput range in terms of IOPS or data rate. For example, 0-INF, 0-400IOPS, 0-200KB/s, 0-400MB/s .
[-is-shared {true|false}] - Is Shared
The shared value specifies whether the policy group is a shared policy group or not.
[-is-auto-generated {true|false}] - Is Policy Auto Generated
The auto-generated value specifies whether the policy group is an automatically generated policy group or not.
cluster1::> qos policy-group show
Name             Vserver     Class        Wklds Throughput
pg1              vs4         user-defined 0     0-200IOPS
pg2              vs0         user-defined 0     0-500IOPS
pg5              vs0         user-defined 0     0-300IOPS
pg6              vs0         user-defined 0     0-INF
4 entries were displayed.
The example above displays all policy groups on the cluster.
