qos policy-group show
Display a list of policy groups
The qos policy-group show command shows the current settings of the policy groups on a cluster. You can display a list of the policy groups and you can view detailed information about a specific policy group.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-policy-group <text>]- Policy Group Name-
Selects the policy groups that match this parameter value
Policy groups define measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
[-vserver <vserver name>]- Vserver-
[-uuid <UUID>]- Uuid-
[-class <QoS Configuration Class>]- Policy Group Class-
[-pgid <integer>]- Policy Group ID-
This uniquely identifies the policy group
[-max-throughput <qos_tput>]- Maximum Throughput-
A maximum throughput limit specifies the throughput (in IOPS or MB/s) that the policy group must not exceed.
[-min-throughput <qos_tput>]- Minimum Throughput-
A minimum throughput specifies the desired performance level for a policy group.
[-num-workloads <integer>]- Number of Workloads-
Selects the policy groups that match this parameter value.
[-throughput-policy <text>]- Throughput Policy-
Selects the policy groups that match this parameter value. You can specify the throughput range in terms of IOPS or data rate. For example,
0-INF, 0-400IOPS, 0-200KB/s, 0-400MB/s. [-is-shared {true|false}]- Is Shared-
The shared value specifies whether the policy group is a shared policy group or not.
[-is-auto-generated {true|false}]- Is Policy Auto Generated-
The auto-generated value specifies whether the policy group is an automatically generated policy group or not.
cluster1::> qos policy-group show Name Vserver Class Wklds Throughput ---------------- ----------- ------------ ----- ------------ pg1 vs4 user-defined 0 0-200IOPS pg2 vs0 user-defined 0 0-500IOPS pg5 vs0 user-defined 0 0-300IOPS pg6 vs0 user-defined 0 0-INF 4 entries were displayed.
The example above displays all policy groups on the cluster.
