security anti-ransomware volume workload-behavior show
Display information about the volume's workload-behavior learnt by the analytics algorithm
This security anti-ransomware volume workload-behavior show displays the workload characteristics observed during anti-ransomware monitoring.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver of the anti-ransomware enabled volume.
 -volume <volume name>- Volume Name-
This parameter specifies the anti-ransomware enabled volume for which the workload behavior details are displayed.
 [-file-extensions-included <text>,…]- List of File Extensions Observed-
This parameter displays the list of file extensions observed during anti-ransomware monitoring.
 [-total-file-extensions-included <integer>]- Number of File Extensions Observed-
This parameter displays the number of file extensions observed during anti-ransomware monitoring.
 [-high-entropy-data-write-peak-percent <integer>]- High Entropy Data Write Peak Percentage-
This parameter displays the peak historical high entropy data write percentage of the incoming data.
 [-high-entropy-data-write-peak-rate <integer>]- High Entropy Data Write Peak Rate (KB/minute)-
This parameter displays the peak historical high entropy data write rate.
 [-file-create-peak-rate <integer>]- File Create Peak Rate per Minute-
This parameter displays the peak historical rate of file create operations in the volume.
 [-file-rename-peak-rate <integer>]- File Rename Peak Rate per Minute-
This parameter displays the peak historical rate of file rename operations in the volume.
 [-file-delete-peak-rate <integer>]- File Delete Peak Rate per Minute-
This parameter displays the peak historical rate of file delete operations in the volume.
 [-surge-timeline <MM/DD/YYYY HH:MM:SS>]- Surge Timeline-
This parameter displays the timeline where a surge was observed in the workload characteristics compared to the historically learnt characteristics.
 [-surge-high-entropy-data-write-peak-percent <integer>]- High Entropy Data Write Percentage During Surge-
This parameter displays the peak percentage value of high entropy data write in the incoming data when the surge was observed.
 [-surge-high-entropy-data-write-peak-rate <integer>]- High Entropy Data-write Peak Rate Surge (KB/minute)-
This parameter displays the peak rate of high entropy data write when the surge was observed.
 [-surge-file-create-peak-rate <integer>]- File Create Peak Rate (per Minute) During Surge-
This parameter displays the surge in the peak rate of file create operations.
 [-surge-file-delete-peak-rate <integer>]- File Delete Peak Rate (per Minute) During Surge-
This parameter displays the surge in the peak rate of file delete operations.
 [-surge-file-rename-peak-rate <integer>]- File Rename Peak Rate (per Minute) During Surge-
This parameter displays the surge in the peak rate of file rename operations.
 [-attack-file-extensions-observed <text>,…]- File Extensions Observed During Attack-
This parameter displays the list of file types observed during a suspected ransomware attack.
 [-attack-file-extensions-observed-counts <integer>,…]- Number of File Extensions Observed During Attack-
This parameter displays the count of various file types observed during a suspected ransomware attack.
The following example shows sample output for this command:
cluster1::> security anti-ransomware volume workload-behavior show -vserver vs1 -volume vol1
                                         Vserver: vs1
                                          Volume: vol1
                        File Extensions Observed: .ext1, .ext2, .ext3
              Number of File Extensions Observed: 3
Historical Statstics
              High Entropy Data Write Percentage: 50
   High Entropy Data Write Peak Rate (KB/Minute): 50
              File Create Peak Rate (per Minute): 100
              File Delete Peak Rate (per Minute): 100
              File Rename Peak Rate (per Minute): 100
Surge Observed
                                  Surge Timeline: 1/1/2022 01:01:01
              High Entropy Data Write Percentage: 200
   High Entropy Data Write Peak Rate (KB/Minute): 200
              File Create Peak Rate (per Minute): 200
              File Delete Peak Rate (per Minute): 200
              File Rename Peak Rate (per Minute): 200
                  Newly Observed File Extensions: .uk1,.uk2,.uk3
        Number of Newly Observed File Extensions: 1, 2, 3
