ONTAP commands
security anti-ransomware volume workload-behavior show
Display information about the volume's workload-behavior learnt by the analytics algorithm
This security anti-ransomware volume workload-behavior show displays the workload characteristics observed during anti-ransomware monitoring.
{ [-fields <fieldname>,…​]
| [-instance ] }
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver of the anti-ransomware enabled volume.
-volume <volume name> - Volume Name
This parameter specifies the anti-ransomware enabled volume for which the workload behavior details are displayed.
[-file-extensions-included <text>,…​] - List of File Extensions Observed
This parameter displays the list of file extensions observed during anti-ransomware monitoring.
[-total-file-extensions-included <integer>] - Number of File Extensions Observed
This parameter displays the number of file extensions observed during anti-ransomware monitoring.
[-high-entropy-data-write-peak-percent <integer>] - High Entropy Data Write Peak Percentage
This parameter displays the peak historical high entropy data write percentage of the incoming data.
[-high-entropy-data-write-peak-rate <integer>] - High Entropy Data Write Peak Rate (KB/minute)
This parameter displays the peak historical high entropy data write rate.
[-file-create-peak-rate <integer>] - File Create Peak Rate per Minute
This parameter displays the peak historical rate of file create operations in the volume.
[-file-rename-peak-rate <integer>] - File Rename Peak Rate per Minute
This parameter displays the peak historical rate of file rename operations in the volume.
[-file-delete-peak-rate <integer>] - File Delete Peak Rate per Minute
This parameter displays the peak historical rate of file delete operations in the volume.
[-surge-timeline <MM/DD/YYYY HH:MM:SS>] - Surge Timeline
This parameter displays the timeline where a surge was observed in the workload characteristics compared to the historically learnt characteristics.
[-surge-high-entropy-data-write-peak-percent <integer>] - High Entropy Data Write Percentage During Surge
This parameter displays the peak percentage value of high entropy data write in the incoming data when the surge was observed.
[-surge-high-entropy-data-write-peak-rate <integer>] - High Entropy Data-write Peak Rate Surge (KB/minute)
This parameter displays the peak rate of high entropy data write when the surge was observed.
[-surge-file-create-peak-rate <integer>] - File Create Peak Rate (per Minute) During Surge
This parameter displays the surge in the peak rate of file create operations.
[-surge-file-delete-peak-rate <integer>] - File Delete Peak Rate (per Minute) During Surge
This parameter displays the surge in the peak rate of file delete operations.
[-surge-file-rename-peak-rate <integer>] - File Rename Peak Rate (per Minute) During Surge
This parameter displays the surge in the peak rate of file rename operations.
[-attack-file-extensions-observed <text>,…​] - File Extensions Observed During Attack
This parameter displays the list of file types observed during a suspected ransomware attack.
[-attack-file-extensions-observed-counts <integer>,…​] - Number of File Extensions Observed During Attack
This parameter displays the count of various file types observed during a suspected ransomware attack.
The following example shows sample output for this command:
cluster1::> security anti-ransomware volume workload-behavior show -vserver vs1 -volume vol1
                       Vserver                  : vs1
                       Volume                   : vol1
                       File Extensions Observed : .ext1, .ext2, .ext3
             Number of File Extensions Observed : 3
Historical Statstics
  High Entropy Data Write Percentage            : 50
  High Entropy Data Write Peak Rate (KB/Minute) : 50
  File Create Peak Rate (per Minute)            : 100
  File Delete Peak Rate (per Minute)            : 100
  File Rename Peak Rate (per Minute)            : 100
Surge Observed
  Surge Timeline                                : 1/1/2022 01:01:01
  High Entropy Data Write Percentage            : 200
  High Entropy Data Write Peak Rate (KB/Minute) : 200
  File Create Peak Rate (per Minute)            : 200
  File Delete Peak Rate (per Minute)            : 200
  File Rename Peak Rate (per Minute)            : 200
  Newly Observed File Extensions                : .uk1,.uk2,.uk3
  Number of Newly Observed File Extensions      : 1, 2, 3
