ONTAP commands
security login lock
Lock a user account with password authentication method
The security login lock command locks a specified account, preventing it from accessing the management interface. This command only applies to user accounts configured with the password authentication method where the password is set.
-vserver <vserver name> - Vserver
This optionally specifies the Vserver to which the user account belongs.
-username <text> - Username
This specifies the user name of the account that is to be locked.
The following example locks a user account named 'jdoe' which belongs to the Vserver 'vs1.netapp.com'.
cluster1::> security login lock -vserver vs1.netapp.com -username jdoe
