storage shelf firmware show-update-status
Display the Shelf Firmware Update (SFU) Status.
The storage shelf firmware show-update-status command displays the state of the Shelf Firmware Update process.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node (privilege: advanced)-
Selects the node that matches this parameter value.
[-update-status {running|idle}]- Disk Shelf Firmware Update Status (privilege: advanced)-
Selects the nodes whose SFU process status matches this parameter value. Possible values are:
running - Disk shelf firmware update is in progress.
idle - Disk shelf firmware update is not in progress.
[-in-progress-count <integer>]- Number of Shelves with Earlier Revisions Being Updated (privilege: advanced)-
Selects the nodes that matches the number of shelves the SFU process is updating to this parameter value. This specifies the number of shelves with earlier revisions that are being updated.
cluster1::*> storage shelf firmware show-update-status
Update In-Progress
Node Status Count
cluster-n1 running 10
cluster-n2 idle -
cluster-n3 running 7
