The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs stop
PDF of this doc site
Creating your file...
Your file is ready
Stop a CIFS server
This command stops the CIFS server on the specified Vserver.
Established sessions will be terminated and their open files closed. Workstations with cached data will not be able to save those changes, which could result in data loss. |
-vserver <vserver name>
- Vserver-
This parameter specifies a Vserver containing a configured CIFS server that is running.
The following example stops the CIFS server on Vserver vs1:
cluster1::> cifs stop -vserver vs1
