      vserver cifs stop
Stop a CIFS server
This command stops the CIFS server on the specified Vserver.
|  | Established sessions will be terminated and their open files closed. Workstations with cached data will not be able to save those changes, which could result in data loss. |
- -vserver <vserver name>- Vserver
This parameter specifies a Vserver containing a configured CIFS server that is running.
The following example stops the CIFS server on Vserver vs1:
cluster1::> cifs stop -vserver vs1
 PDFs
PDFs
