The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security session limit request create
PDF of this doc site
Creating your file...
Your file is ready
Create per-request session limit
This command allows creation of a per-request management session limit that does not yet exist.
-interface {cli|ontapi|rest}
- Interface (privilege: advanced)-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-request <text>
- Request Name (privilege: advanced)-
The specified request to which this limit applies. The limit with the request name
-default-
is the limit used for any request without a specific configured limit. -max-active-limit <integer>
- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and request.
The following example illustrates creating a limit for number of clients executing a specific API.
cluster1::*> security session limit request create -interface ontapi -request storage-disk-get-iter -max-active-limit 2
