security session limit request create
Create per-request session limit
This command allows creation of a per-request management session limit that does not yet exist.
-interface {cli|ontapi|rest}
- Interface-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-request <text>
- Request Name-
The specified request to which this limit applies. The limit with the request name
-default-
is the limit used for any request without a specific configured limit. -max-active-limit <integer>
- Max-Active Limit-
The maximum number of concurrent sessions allowed for this interface and request.
The following example illustrates creating a limit for number of clients executing a specific API.
cluster1::*> security session limit request create -interface ontapi -request storage-disk-get-iter -max-active-limit 2
