      network tuning icmp6 modify
Modify ICMPv6 tuning options
This command displays options which can be used to fine tune icmpv6 protocol behavior.
- -node {<nodename>|local}- Node
Sets this parameter to indicate on which node the ICMPv6 tuning options are modified.
- [-is-v6-redirect-accepted {true|false}]- Accept redirects via ICMPv6
Sets this parameter to indicate whether or not redirect ICMPv6 messages are accepted.
- [-redirect-v6-timeout <integer>]- Maximum seconds for route redirect timeout
Sets this parameter to indicate the number of seconds after which the route is deleted. Value of zero means infinity. The default value is 300 seconds.
- [-tx-icmp6-err-limit <integer>]- Maximum number of ICMPv6 error messages sent per second
Sets the maximum number of ICMPv6 error messages that can be sent per second.
cluster1::> network tuning icmp6 modify -node node1 -is-v6-redirect-accepted false
 PDFs
PDFs
