network options detect-switchless-cluster modify
Modify the status of switchless cluster detection
This command enables or disables the automatic detection of a switchless cluster. A switchless cluster consists of two nodes where the cluster ports are directly connected without a switch between them.
[-enabled {true|false}]
- Enable Switchless Cluster Detection (privilege: advanced)-
This parameter specifies whether switchless cluster detection is enabled or not. Setting this parameter to
true
enables switchless cluster detection.
The following example enables switchless cluster detection: cluster1::*> network options detect-switchless-cluster modify -enabled true
