security login totp create
Add a TOTP secret
The security login totp create associates an new secret key with a user account. This command requires that you enter a user name.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the user for whom you are adding the secret key.
-username <text>- Username-
This parameter specifies the name of the user for whom you are adding the secret key. If you do not specify a user in case of Cserver, the user named admin is specified by default. If it is a data vserver, it defaults to logged-in user
[-comment <text>]- Comment-
This optionally specifies comment text for the TOTP key. Note that comment text should be enclosed in quotation marks.
The following command creates a secret key with a user named tsmith for Vserver vs1. The secret key has a comment text is “This is a new key”.
cluster1::> security login totp create -vserver vs1 -username tsmith -comment "This is a new key"
