event notification modify
Modify event notifications
The event notification modify command is used to modify an existing notification.
-ID <integer>- Event Notification ID-
Use this mandatory parameter to specify the ID of the notification to be modified.
[-filter-name <text>]- Event Filter Name-
Use this parameter to specify the filter name to be modified.
[-destinations <text>,…]- List of Event Notification Destinations-
Use this parameter to specify the destinations to be modified. Enter multiple destinations separated by a comma.
Provide the complete set of destinations to be modified. Individual destinations cannot be added or removed.
The following example shows the modification of the event notification with ID 1:
cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest, snmp-traphost cluster1::> event notification modify -ID 1 -destinations email_dest, syslog_dest cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest
