The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver consistency-group delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an existing consistency group
The vserver consistency-group delete
command can be used to delete a consistency group.
-vserver <Vserver Name>
- Vserver Name-
This parameter specifies the Vserver that contains the consistency group that is to be deleted.
-consistency-group <text>
- Consistency Group Name-
This parameter specifies the consistency group that is to be deleted.
-parent-consistency-group <text>
- Parent Consistency Group Name-
This parameter specifies the parent consistency group of the consistency group that is to be deleted.
The following command deletes the consistency group parentCG in Vserver vs0.
cluster1::> vserver consistency-group delete -vserver vs0 -consistency-group parentCG -parent-consistency-group - (vserver consistency-group delete) Warning: Are you sure you want to delete consistency group "parentCG" in Vserver "vs0" ? {y|n}: y [Job 174] Job succeeded: Success 1 entry was deleted.
