storage array remove
Remove a storage array record from the array profile database.
The storage array remove command discards array profile records for a particular storage array from the cluster database. The command fails if a storage array is still connected to the cluster. Use the storage array config show command to view the array connectivity status. The array target port can be removed using the storage array port remove command.
-name <text>- Name-
Name of the storage array you want to remove from the database.
cluster1::> storage array remove IBM_1722_1
