ONTAP commands
storage array remove
Remove a storage array record from the array profile database.
The storage array remove command discards array profile records for a particular storage array from the cluster database. Upon command completion, if a storage array is still connected to the cluster, the array profile record is re-created with default values.
-name <text> - Name
Name of the storage array you want to remove from the database.
cluster1::> storage array remove IBM_1722_1
