      network port vlan delete
Delete a virtual LAN (VLAN)
The network port vlan delete command deletes a VLAN from a network port.
|  | When you delete a VLAN port, it is automatically removed from all failover rules and groups that use it. |
- -node {<nodename>|local}- Node
The node from which the VLAN is to be deleted.
- { -vlan-name {<netport>|<ifgrp>}- VLAN Name
The name of the VLAN that is to be deleted
- | -port {<netport>|<ifgrp>}- Associated Network Port
The network port to which the VLAN is to be attached.
- -vlan-id <integer>- Network Switch VLAN Identifier }
The ID tag of the deleted VLAN.
This example shows how to delete VLAN e1c-80 from network port e1c on node1.
cluster1::> network port vlan delete -node node1 -vlan-name e1c-80
 PDFs
PDFs
