      system controller config show-errors
Display configuration errors
The system controller config show-errors displays configuration errors.
node
description
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information for all the PCI devices.
 [-node {<nodename>|local}]- Node-
Displays configuration errors on the specified node.
 [-verbose <true>]- Verbose Output?-
The
-verboseparameter enables verbose mode, resulting in the display of more detailed output. [-description <text>]- Error Description-
Displays the node with the specified configuration error.
The example below displays configuration errors on all the nodes in the cluster.
cluster1::> system controller config show-errors Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ Chelsio T320E 2x10G NIC card (PN X1008A) in slot 1 is not supported on model FAS3210 Configuration Info and Errors for Node: cluster1-02 ------------------------------------------------------------------------------ PCI-E Dual 10/100/1000 Ethernet G20 card (PN X1039A) in slot 2 is not supported on model FAS3210 cluster1::> cluster1::> system controller config show-errors -verbose Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ sysconfig: Card in slot 2 (7-1275-0008-46848) is not supported. sysconfig: slot 12 OK: X2067: Proprietary embedded SAS HBA cluster1::>
