The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system controller config show-errors
PDF of this doc site
Creating your file...
Your file is ready
Display configuration errors
The system controller config show-errors
displays configuration errors.
node
description
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information for all the PCI devices.
[-node {<nodename>|local}]
- Node-
Displays configuration errors on the specified node.
[-verbose <true>]
- Verbose Output?-
The
-verbose
parameter enables verbose mode, resulting in the display of more detailed output. [-description <text>]
- Error Description-
Displays the node with the specified configuration error.
The example below displays configuration errors on all the nodes in the cluster.
cluster1::> system controller config show-errors Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ Chelsio T320E 2x10G NIC card (PN X1008A) in slot 1 is not supported on model FAS3210 Configuration Info and Errors for Node: cluster1-02 ------------------------------------------------------------------------------ PCI-E Dual 10/100/1000 Ethernet G20 card (PN X1039A) in slot 2 is not supported on model FAS3210 cluster1::> cluster1::> system controller config show-errors -verbose Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ sysconfig: Card in slot 2 (7-1275-0008-46848) is not supported. sysconfig: slot 12 OK: X2067: Proprietary embedded SAS HBA cluster1::>
