system controller config show-errors
Display configuration errors
The system controller config show-errors displays configuration errors.
  • node
  • description
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information for all the PCI devices.
[-node {<nodename>|local}] - Node
Displays configuration errors on the specified node.
[-verbose <true>] - Verbose Output?
The -verbose parameter enables verbose mode, resulting in the display of more detailed output.
[-description <text>] - Error Description
Displays the node with the specified configuration error.
The example below displays configuration errors on all the nodes in the cluster.
cluster1::> system controller config show-errors
Configuration Info and Errors for Node: cluster1-01
Chelsio T320E 2x10G NIC card (PN X1008A) in slot 1 is not supported on model FAS3210
Configuration Info and Errors for Node: cluster1-02
PCI-E Dual 10/100/1000 Ethernet G20 card (PN X1039A) in slot 2 is not supported on model FAS3210
cluster1::>
cluster1::> system controller config show-errors -verbose
sysconfig: Card in slot 2 (7-1275-0008-46848) is not supported.
sysconfig: slot 12 OK: X2067: Proprietary embedded SAS HBA
cluster1::>
