ONTAP commands
vserver snapdiff-rpc-server on
Start the SnapDiff RPC Server
The vserver snapdiff-rpc-server on command turns the SnapDiff RPC server on.
-vserver <vserver name> - Vserver (privilege: advanced)
This parameter specifies the Vserver for which you want to turn the SnapDiff RPC server on.
The following example enables the SnapDiff RPC server access for a Vserver named vs0:
cluster1::> vserver snapdiff-rpc-server on -vserver vs0
