ONTAP commands
storage tape config-file delete
Delete a tape config file
The storage tape config-file delete command deletes the specified tape drive configuration file from all nodes that are currently part of the cluster.
-filename <text> - Config File Filename (privilege: advanced)
This parameter specifies the name of the tape configuration file that will be deleted from all nodes that are currently part of the cluster.
The following example deletes the specified tape drive configuration files on every node that is currently part of the cluster:
cluster1::> storage tape config-file delete -filename XYZ_LTO-6.TCF
