The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock log delete
PDF of this doc site
Creating your file...
Your file is ready
Delete audit log configuration for a Vserver.
The snaplock log delete
command deletes the SnapLock log configuration associated with the Vserver. This command closes all the active log files in the log volume and mark the volume as disabled for SnapLock logging.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver whose SnapLock log configuration is deleted.
cluster1::> snaplock log delete -vserver vs1 [Job 47] Job succeeded: SnapLock log deleted for Vserver "vs1".
