vserver fpolicy persistent-store delete
Delete a persist store
The vserver fpolicy persistent-store delete command deletes an Fpolicy persistent store.
-vserver <Vserver Name>- Vserver-
This parameter specifies the name of the Vserver from which you want to delete the FPolicy persistent store.
-persistent-store <text>- Persistent Store Name-
This parameter specifies the name of the FPolicy persistent store that you want to delete.
The following example deletes an FPolicy persistent store.
cluster1::> vserver fpolicy persistent-store delete -vserver vs1.example.com -persistent-store ps1
