vserver fpolicy persistent-store delete
Delete a Persist Store
The vserver fpolicy persistent-store delete command deletes an FPolicy Persistent Store.
-vserver <Vserver Name>- Vserver-
This parameter specifies the name of the Vserver from which you want to delete the FPolicy Persistent Store.
-persistent-store <text>- Persistent Store Name-
This parameter specifies the name of the FPolicy Persistent Store that you want to delete.
[-delete-volume {true|false}]- Delete the Persistent Store Volume-
This parameter specifies if the associated volume for the FPolicy Persistent Store has to be deleted. By default, it will be false.
The following example deletes an FPolicy Persistent Store.
cluster1::> vserver fpolicy persistent-store delete -vserver vs1.example.com -persistent-store ps1 -delete-volume true
