ONTAP commands
metrocluster configuration-settings show-status
Display the configuration settings status for a MetroCluster setup
The metrocluster configuration-settings show-status command displays the configuration settings status for nodes in a MetroCluster setup. If a DR group has not been created, then status for nodes in the local cluster only are displayed.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
If this parameter is specified, the command displays detailed information about all entries.
[-cluster-uuid <UUID>] - Cluster UUID
If this parameter is specified, the command displays detailed information about all nodes in the cluster matching the specified cluster-uuid.
[-cluster <Cluster name>] - Cluster Name
If this parameter is specified, the command displays detailed information about all the nodes in the specified cluster.
[-node <text>] - Node Name
If this parameter is specified, the command displays information for the matching nodes.
[-configuration-status <text>] - Configuration Settings Status
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration status.
[-config-error-info <text>] - Configuration Error Information
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration error information.
The following example shows the display of MetroCluster setup status:
Nodes do not have a valid platform-specific personality value (equivalent to HAOSC parameter on non-Apollo platforms) for a MetroCluster setup.
clusA::> metrocluster configuration-settings show-status
Cluster                    Node               Configuration Settings Status
   clusA                      A1                 not a MetroCluster setup
                              A2                 not a MetroCluster setup
2 entries were displayed.
MetroCluster setup uses FC links rather than IP link:
clusA                      A1                 not applicable for FC and SAS
                           A2                 not applicable for FC and SAS
Output of the command when MetroCluster setup uses IP links and before `"metrocluster configuration-settings dr-group create"` command is run:
clusA                      A1                 ready for DR group create
                           A2                 ready for DR group create
Output of the command after `"metrocluster configuration-settings dr-group create"` command is run:
clusA
                           A1                 ready for interface create
                           A2                 ready for interface create
clusB
                           B1                 ready for interface create
                           B2                 ready for interface create
4 entries were displayed.
Output of the command after `"metrocluster configuration-settings interface create"` command is run for every node:
clusA
                           A1                 ready for next interface create
                           A2                 ready for connection connect
clusB
                           B1                 ready for connection connect
                           B2                 ready for connection connect
Output of the command after ` "metrocluster configuration-settings connection connect" ` command is run:
clusA
                           A1                 completed
                           A2                 completed
clusB
                           B1                 completed
                           B2                 completed
Output of the command after ` "metrocluster configuration-settings connection connect"` command is run and there are connection errors:
clusA                      A1                 connection error
                           A2                 completed
clusB                      B1                 connection error
                           B2                 completed
