metrocluster configuration-settings show-status
Display the configuration settings status for a MetroCluster setup
The metrocluster configuration-settings show-status command displays the configuration settings status for nodes in a MetroCluster setup. If a DR group has not been created, then status for nodes in the local cluster only are displayed.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
If this parameter is specified, the command displays detailed information about all entries.
[-cluster-uuid <UUID>]- Cluster UUID-
If this parameter is specified, the command displays detailed information about all nodes in the cluster matching the specified cluster-uuid.
[-cluster <Cluster name>]- Cluster Name-
If this parameter is specified, the command displays detailed information about all the nodes in the specified cluster.
[-node <text>]- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
[-configuration-status <text>]- Configuration Settings Status-
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration status.
[-config-error-info <text>]- Configuration Error Information-
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration error information.
The following example shows the display of MetroCluster setup status:
Nodes do not have a valid platform-specific personality value (equivalent to HAOSC parameter on non-Apollo platforms) for a MetroCluster setup.
clusA::> metrocluster configuration-settings show-status
Cluster Node Configuration Settings Status
clusA A1 not a MetroCluster setup
A2 not a MetroCluster setup
2 entries were displayed.
MetroCluster setup uses FC links rather than IP link:
clusA A1 not applicable for FC and SAS
A2 not applicable for FC and SAS
Output of the command when MetroCluster setup uses IP links and before `"metrocluster configuration-settings dr-group create"` command is run:
clusA A1 ready for DR group create
A2 ready for DR group create
Output of the command after `"metrocluster configuration-settings dr-group create"` command is run:
clusA
A1 ready for interface create
A2 ready for interface create
clusB
B1 ready for interface create
B2 ready for interface create
4 entries were displayed.
Output of the command after `"metrocluster configuration-settings interface create"` command is run for every node:
clusA
A1 ready for next interface create
A2 ready for connection connect
clusB
B1 ready for connection connect
B2 ready for connection connect
Output of the command after ` "metrocluster configuration-settings connection connect" ` command is run:
clusA
A1 completed
A2 completed
clusB
B1 completed
B2 completed
Output of the command after ` "metrocluster configuration-settings connection connect"` command is run and there are connection errors:
clusA A1 connection error
A2 completed
clusB B1 connection error
B2 completed
