metrocluster configuration-settings show-status
PDF of this doc site
Creating your file...
Display the configuration settings status for a MetroCluster setup
The metrocluster configuration-settings show-status
command displays the configuration settings status for nodes in a MetroCluster setup. If a DR group has not been created, then status for nodes in the local cluster only are displayed.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
If this parameter is specified, the command displays detailed information about all entries.
[-cluster-uuid <UUID>]
- Cluster UUID-
If this parameter is specified, the command displays detailed information about all nodes in the cluster matching the specified cluster-uuid.
[-cluster <Cluster name>]
- Cluster Name-
If this parameter is specified, the command displays detailed information about all the nodes in the specified cluster.
[-node <text>]
- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
[-configuration-status <text>]
- Configuration Settings Status-
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration status.
[-config-error-info <text>]
- Configuration Error Information-
If this parameter is specified, the command displays detailed information about all nodes with the specified configuration error information.
The following example shows the display of MetroCluster setup status:
Nodes do not have a valid platform-specific personality value (equivalent to HAOSC parameter on non-Apollo platforms) for a MetroCluster setup. clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ -------------------------------- clusA A1 not a MetroCluster setup A2 not a MetroCluster setup 2 entries were displayed. MetroCluster setup uses FC links rather than IP link: clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ -------------------------------- clusA A1 not applicable for FC and SAS A2 not applicable for FC and SAS 2 entries were displayed. Output of the command when MetroCluster setup uses IP links and before `"metrocluster configuration-settings dr-group create"` command is run: clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ -------------------------------- clusA A1 ready for DR group create A2 ready for DR group create 2 entries were displayed. Output of the command after `"metrocluster configuration-settings dr-group create"` command is run: clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 ready for interface create A2 ready for interface create clusB B1 ready for interface create B2 ready for interface create 4 entries were displayed. Output of the command after `"metrocluster configuration-settings interface create"` command is run for every node: clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 ready for next interface create A2 ready for connection connect clusB B1 ready for connection connect B2 ready for connection connect 4 entries were displayed. Output of the command after ` "metrocluster configuration-settings connection connect" ` command is run: usA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 completed A2 completed clusB B1 completed B2 completed 4 entries were displayed. Output of the command after ` "metrocluster configuration-settings connection connect"` command is run and there are connection errors: clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ -------------------------------- clusA A1 connection error A2 completed clusB B1 connection error B2 completed 4 entries were displayed.
