volume efficiency on
Enable efficiency on a volume
The volume efficiency on command enables efficiency on a volume. The specified volume must be online. Efficiency operations will be started periodically according to a per volume schedule or policy. The volume efficiency modify command can be used to modify schedule and the volume efficiency policy modify command can be used to modify policy. You can also manually start an efficiency operation with the volume efficiency start command.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name -
This specifies the name of the volume on which efficiency needs to be enabled.
-path </vol/volume>- Volume Path } -
This specifies the volume path on which efficiency needs to be enabled.
The following examples enable efficiency on a volume.
cluster1::> volume efficiency on -vserver vs1 -volume vol1
cluster1::> volume efficiency on -vserver vs1 -path /vol/vol1
